Plug and Play with Prime 2.2
Evelyn Riha
Has anybody worked with the Plug and Play features on Prime 2.2? After applying the bootstrap config coming from Prime manually the switch is not showing up in Prime and the following errors are popping up.
*Mar  1 00:02:06.785: %CNS-3-TRANSPORT: CNS_HTTP_CONNECTION_FAILED:prime -Process= "CNS config initial", ipl= 0, pid= 302
*Mar  1 00:02:06.785: %CNS-3-TRANSPORT: CNS_HTTP_CONNECTION_FAILED -Process= "CNS config initial", ipl= 0, pid= 302
Capturing the traffic in Wireshark there is an ongoing SSL connection between Prime an the switch.
Am I missing something here? Any clues what's going on?
Many thanks,
Evelyn
jonathanrosas
did you find the solution? I have the same issue
