PnP Add Device API not accepting stackMemberList inside stackInfo
srajakri
API Endpoint
/dna/intent/api/v1/onboarding/pnp-device
PAYLOAD
"deviceInfo": {
"serialNumber": "FOC2724Y3SP",
"stack": "True",
"description": "string",
"pid": "C9300X-48HX",
"siteId": "fad85e73-6051-49ed-94e2-7c098c0a6721",
"sudiRequired": "False",
"hostname": "svlgold24-sw1",
"stackInfo": {
"supportsStackWorkflows": "True",
"isFullRing": "True",
"stackMemberList": [
"serialNumber": "FVH2814L9ZC",
"role": "Active",
"stackNumber": "1",
"priority": "13",
"serialNumber": "FOC2724Y9AB",
"role": "Standby",
"stackNumber": "2",
"priority": "12",
"totalMemberCount": "2"
RESPONSE
"stackInfo": {
"isFullRing": true,
"supportsStackWorkflows": true,
"totalMemberCount": 2,
"stackMemberList": [],
"validLicenseLevels": [
"Cisco DNA Essentials",
"Cisco DNA Advantage",
"IP Services",
"Lanbase"
stackMemberList always returns empty, please help
11 Replies 11
Try and update this line "stackMemberList": stack_info.get("stackMemberList", []),
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
Do you mean like this ?
"stackMemberList" : stack_info.get("stackMemberList", [{
"role": "Active",
"stackNumber": "1",
"priority": "13",
Yes, try this.
Where is 'stack_info' defined ? any documentation
Its a Python boolean flag (True/False), stack_info is a keyword argument used within a logging function, the get which is normally associated with dictionaries, and used to retrieve the value associated with a specific key. Here is a doc link https://docs.python.org/3/library/logging.html
srajakri
I'm sorry i didnt get you how the stack_info here is related to stack_info in logging module, i'm not even using logging module in my code , please provide payload example
Sorry i see what you mean, i thought you meant something else. Try if  "stack": "True" and "stackInfo.supportsStackWorkflows": "True" should be in the boolean values (true/false) instead of strings, something llike this maybe?
  "deviceInfo": {
    "stack": true,
    "stackInfo": {
srajakri
pnp_import_info = [
"deviceInfo": {
"hostname": device_name,
"serialNumber": device_serial,
"pid": device_pid,
"sudiRequired": False,
"stack": True,
"userSudiSerialNos": [],
"aaaCredentials": {
"username": "",
"password": ""
"stackInfo": {
"supportsStackWorkflows": True,
"serialNumber": "FVH2814L2BB",
"role": "Active",
"stackNumber": "1",
"priority": "13",
"pid": device_pid
"role": "Standby",
"stackNumber": "2",
"priority": "12",
"pid": device_pid
"stackRingProtocol": "StackWise",
srajakri
Above with boolean True aint working either. devices is added successfully as stack but stackMemberlist is not getting populated
Hmm thats odd, i wonder if this is an API handling issue? The new code you shared, the stackInfo is at the same level as deviceInfo in your payload, on the previous working example, stackInfo should be nested inside deviceInfo, try
pnp_import_info = [
        "deviceInfo": {
            "pid": device_pid,
            "stack": True,
            "aaaCredentials": {
                "username": "",
                "password": ""
            "stackInfo": {  # Moved inside deviceInfo
                        "role": "Active",
                        "stackNumber": "1",
                        "priority": "13",
                        "pid": device_pid
                        "role": "Standby",
                        "stackNumber": "2",
                        "priority": "12",
                        "pid": device_pid
srajakri
Thank you, fixed that, but the stackmemberlist is still empty
'stackMemberList': []
