Port-based RSTP Monitoring via SNMP
gregoryalussier
Hi everyone,
I was wondering if there was any way to monitor a switch port using the SNMP protocol to poll for information about the RSTP port state? For instance, I would like to trigger alerts when a ports transitions from forwarding to blocking state. I tried to find the MIB there http://www.cisco.com/public/sw-center/netmgmt/cmtk/mibs.shtml but I could not find any matching my needs.
Thanks a lot,
G.
Dan Frey
BRIDGE-MIB has the OIDs to monitor RSTP.
  topologyChange NOTIFICATION-TYPE
       -- OBJECTS     { }
       STATUS      current
       DESCRIPTION
           "A topologyChange trap is sent by a bridge when any of
           its configured ports transitions from the Learning state
           to the Forwarding state, or from the Forwarding state to
           the Blocking state.  The trap is not sent if a newRoot
           trap is sent for the same transition.  Implementation of
           this trap is optional."
       ::= { dot1dNotifications 2 }
dot1dStpPortState OBJECT-TYPE
       SYNTAX      INTEGER {
                       disabled(1),
                       blocking(2),
                       listening(3),
                       learning(4),
                       forwarding(5),
                       broken(6)
       MAX-ACCESS  read-only
       STATUS      current
       DESCRIPTION
           "The port's current state, as defined by application of
           the Spanning Tree Protocol.  This state controls what
           action a port takes on reception of a frame.  If the
           bridge has detected a port that is malfunctioning, it
           will place that port into the broken(6) state.  For
           ports that are disabled (see dot1dStpPortEnable), this
           object will have a value of disabled(1)."
       REFERENCE
           "IEEE 802.1D-1998: clause 8.5.5.2"
       ::= { dot1dStpPortEntry 3 }
