Port Capacity Management
leemounty
Hi there,
I'm not a technical engineer but need to oversee the capacity planning of a large network of 2950/3750 switches.  If I was able to get an output of just the switch/port and the last time it was used for each port in the organisation (one per line) it would allow me to see what is still active and also spot trends.  Does anyone know of a good way of doing this or is there a better alternative.  I was thinking it might be something the RME could do or something messy like SecureCRT.  Any help appreciated.
L
Robert Pavone
Lee,
You can get the port capacity reports under Campus Manager --> User Tracking --> Report Generator --> Select Switch Port Report --> select Switch Port Capacity or Recently Down
Rob
