Port Security on cisco switch2960 series
tmourad01
Hi ,
i used the following command to apply the port-security on the switch ports.
#enable
#conf t
#interface f0/1
#switchport mode access
#switchport port-security
#switchport port-security maximum 1
#switchport port-security mac-address sticky
#switchport port-security violation shutdown
#end
#write
question 1 : what does the sticky command exactly do? and what the difference between #switchport port-security mac-address sticky and #switchport port-security mac-address 0001.2BDE.UHT5
question 2 : if i restart the switch the configuration will gone or it is still saved in the switch configuration?
question 3:if i have a device where his MAC address is allowed on a port on the switch, and for some reason the device is damage and needs to be replaced by a new one. what is the way to allow the new device to access the same port?
question 3 : how to disable the port-security on a port?
question 4 : if a device or mac address is not allowed on a port, once is plugged in this port a violation is declared and in our case the port will shutdown. if i take this mac address and plug it on the same switch using another port where port-security is disable, the device is blocked or not on the port?
i want to thank you again for all your help for me.
have a good day.
best regards ,
tmourad01
thanks for your prompt response.
