Portal problems after upgrading to LMS 3.2
s.leyer
Hi !
After upgrading from LMS 3.1 on 3.2 I can't access the LMS portal anymore.
The following error is displayed :
HTTP Status 404 - /CSCOnm/servlet/login/login.jsp
type Status report
message /CSCOnm/servlet/login/login.jsp
description The requested resource (/CSCOnm/servlet/login/login.jsp) is not available.
Apache Tomcat/5.5.17
LMS is running on Solaris 10.
Messages in stdout.log don't look well.
Attached you'll find the output from pdshow, pdreg -l Apache and stdout.log
Thanks for help
Silvia
Joe Clarke
No, this is bad. It looks like your installation failed. You are missing /opt/CSCOpx/lib/classpath/com/cisco/nm/cmf/util/AccessLogFilter.class and /opt/CSCOpx/lib/classpath/com/cisco/nm/xms/security/crypto/InvalidKeyException.class at the very least.
At this point, I recommend you uninstall LMS from this server, then reinstall 3.2 from scratch. Then restore the previous version's backup into 3.2.
Ok, that's what I'll do then.
Thanks for the evaluation
