Prevent "no" Under a Particular Interface
jasocole09
I want to figure out how I can use EEM to prevent all users from running a "no" command on a particular interface.
Normally I would right something like:
event manager applet PREVENT-POLICY-MAP-REMOVAL
event cli pattern "no *" sync no skip yes
action 1.0 syslog msg "DO NOT REMOVE A SERVICE POLICIES FROM THIS PORT"
However, this would prevent the command under all configuration modes.  I just want the EEM script to protect a single ethernet port.  Without using AAA authorization (local privileges) or TACACS authorization, how could I do this?
Dan Frey
Try this applet to block "no commands" under the interface.
event manager applet cmd
 event cli pattern "no *" mode "interface" enter
 action 1.0 syslog msg "NO Commands not allowed under interface mode"
 action 2.0 set _exit_status "0"
