Prime 3.0 not showing "Refresh Config from Controller" in Menu
Tobias Heisele
Level 3
Level 3
Unter "Network Devices" / "Device Type" / "Wireless Controller" in Menu "Configure" the option "refresh config from controller", which should be the 2nd entry, is missing. In Prime 2.2, whose backup was used for Prime 3.0, this option is avaiable. Is this a bug or a feature?
daniel.litwin
Step 1 Choose Configuration > Network > Network Devices, then select Device Type > Wireless Controller.
Step 2 Select the check box(es) of the applicable controller(s).
Step 3 Click Configure > Audit Now.
It will then go and audit the controller.  It will let you know there is a mismatch, and you can choose to refresh config from the controller back to Prime Infra
