Remote ping
parm UK
Hi guys,
After some advice please.
I need to monitor some devices that sit behind certain routers / l3 switches.
Ideally I want to issue a remote ping fom the router and get an alert if ping fails.   Currently we use prtg for snmp monitoring and I can't work out how to do this.
Can I use cisco prime infrastructure to do this?   I've dloads the trial,  just need  to know  how I can issue the remote ping and poll the results.   Alternatively if I can monitor / alert on the status of a track reachability that would be ideal.
I can see manageengine offer a 'proxy ping' out the box
https://www.manageengine.com/products/oputils/help/diagnostics/proxy_ping_tool.html
Any suggestions greatly appreciated.
6 Replies 6
Hi Parm,
actually the PRTG allows to send an e-mail if the SNMP polling fails (depending on the configured timeout).
Either way, if you wanted to try through a PING test, I think the easiest way to get an alert if the ping will fails could be a little script like that:
http://stackoverflow.com/questions/2953462/pinging-servers-in-python
Of course it's possible to use differents methods, also PHP would be fine, it's easy to manage even for the beginners indeed .
Then you can trigger a whatever alert like an email or sms (through sms gateway etc..) depending on your needs.
I suggest to try the "scripting" way, as it easy, quick and very handy in case you would like to set up a cost '0' solution to monitor a very critical service.
Hope this helps,
Ciao
L.
+1, I would be using PRTG.  If you really want you can configure IP SLA to make one router ping another router/switch, and then have PRTG monitor the IP sla results.
That's exactly what I would like to do.
For instance I have a 3750 which is already monitored in prtg.
I have the following ip sla
Config:
IP sla 100
icmp-echo x.x.x.x
threshold 10
timeout 1000
frequency 3
ip sla schedule 100 start-time now life forever
track 100 ip sla 100 reachability
I need some help in how I get prtg to monitor this ip  sla / track result.
You help appreciated
Just add the "ip sla" sensor ...
https://www.paessler.com/ip_sla_monitoring
Thanks P.dath.
i cant belive i missed this.   i was exploring cisco mibs in prtg :(
I prefer doing it the easy way.  :-)
