02-11-2020 04:36 AM
I have installed and implemented Prime 3.6.
Everything working correct.
Now I noticed I cant access web, from ssh I found this:
prime/admin# show application status ncs
% Application ncs is not installed
prime/admin# show version
Cisco Application Deployment Engine OS Release: 4.1
ADE-OS Build Version: 4.1.0.001
ADE-OS System Architecture: x86_64
Copyright (c) 2009-2019 by Cisco Systems, Inc.
All rights reserved.
Hostname: prime
Version information of installed applications
Cisco Prime Infrastructure
Version : 3.6.0 [FIPS not Enabled]
Build : 3.6.0.0.172
Critical Fixes:
PI 3.6 Update 02 ( 2.0.0 )
02-11-2020 07:24 AM
- This is very bad , it should give a list of services all up and running. Try ncs stop followed by ncs start and check the status of Prime again. If that does not help - reboot and watch the native console for errors during startup. If still no-go then re-install Prime. Keep a record of the installation process, carefully review it afterwards.
M.
11-12-2021 02:16 AM
The show command is misspelled.
NCS must be written in uppercase, the correct command is:
show application status NCS
