Prime Alerting
ericdavis
Community Member
Is there a way to removed interfaces from being monitored?  I keep getting alerts for interfaces that will never be "UP", but I don't where to remove them from that alert setting.
Mark Elsen
 - This seems to be a wireless controller ; for the unused ports you can use this command :
                    config port adminmode 5 disable
That's an example; subsitute '5' for the correct port number(s)
M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
