12-30-2014 07:46 AM
Hi All,
How can i limit the Alarms on the Prime Infra Structure 2.X , for example Alarm "Port 'GigabitEthernet2/0/22' is down on device '10.40.128.8'." . I don't want to receive such Alarms because it is consuming about 50% of the alarms in my project because on daily basis with the customer leave the site they power off some switches .
Solved! Go to Solution.
12-30-2014 05:00 PM
Hi ,
some notification types cannot be controlled with the snmp-server enable command. For example, some notification types are always enabled. Other notification types are enabled by a different command.
For example, the linkUpDown notifications are controlled by the snmp trap link-status command. These notification types do not require an snmp-server enable command.
The availability of a notification-type option depends on the router type and Cisco IOS software features supported on the router
You would need to disable it from the interfaces ONLY , this can't be done globally.
config # no snmp trap link-status
Thanks-
Afroz
***Ratings Encourages Contributors *****
12-30-2014 08:10 AM
Hi ,
AFAIk, there isn't any way to stop or limit the Alarms\traps in PI.
this you would need to do it from the device it self ,either disable the linkup-linkdown trap globally or go tp the specific interface and disable the trap.
Thanks-
Afroz
****Ratings Encourages Contributors ****
12-30-2014 10:31 AM
The only trap i can find on the switches is the below :
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
So should i delete that command from all switches to stop that type of Alarm on the Prime ?
12-30-2014 05:00 PM
Hi ,
Thanks-
Afroz
