Prime Infrastructure 3.1 Setting Up Lync Monitoring
heikamp
the User Guide of Prime Infrastructure 3.1,Chapter: Monitoring Microsoft Lync Traffic stated:
<add key= “clientcertificateid” value=“value”/>
where value is the certificate value of your Prime Infrastructure server as specified in the Trusted Root Certification Authorities certificate
Can someone please clarify, what is meant with value in detail and give an example?
Thanks & best regards,
Mario
didierdebrouwer
Hi Mario;
"value" should be the exact name as specified in the certificate of your prime server, i.e the exact CN.
so for the example, if your CN is MYPRIMESERVER (https://myprimeserver); the the value should be MYPRIMESERVER.
Hope this helps
