Prime Infrastructure - Cant create motd banner using Compliance Fix Job
dragon20071
Hi. I created a compliance policy that need to check configured login or motd banner exist on a switch.
When my audit job has stopped and i got some devices with violation failure, i have to start a fix job with preconfigured cli command.
Fix cli looks like this:
banner motd #
                       Authorized Access Only!
       Attention! Youre connecting to private computer system.
                All access and actions are logged!
  If youre not an authorized person, please disconnect immediately!
do write memory
But in the end of fix job i constantly got a failure with that message:
"Error : Connection timed out while executing the command
 Current output : banner motd #Enter TEXT message. End with the character '#'.
 Current expects : (2002-asw-1.{0,30}|2002-asw-1.boaz)([^)]+)#s*z2002-asw-1.boaz#s*z[y/n]ACCEPT? (yes/[no]): "
 2002-asw-1.boaz its a hostname of my switch
 What exactly switch expects in cli according to this error? Some regular expression?
superego
You have to use Multiline Command.
<MLTCMD> banner motd ~
BANNER Message Here
~</MLTCMD>
end
wr mem
Refer to:
https://www.cisco.com/c/en/us/support/docs/cloud-systems-management/prime-infrastructure/211574-PI-3-2-Creation-of-User-Defined-CLI-Tem.html
Please rate helpful posts***
superego
BANNER Message Here
~</MLTCMD>
end
wr mem
Refer to:
Great!
Hi!
Helped me out too! Thanks!
Now I would like to add a variable in the banner with dynamic hostname and domain upon login, by adding $(hostname).$(domain). And this actually works in the template and pushing it to the switches, but the job in Prime turns red, with this error:
Error : Connnection timed out while executing the command Current output : switchname10#Current expects : switchname1.{0,30}([^)]+)#s*zYou are entering device #s*z
Here is the complete banner:
<MLTCMD> banner login ~
Property of Company X
Authorized access only!
You are entering device >>> $(hostname).$(domain)
~</MLTCMD>
And the switch hostname is, switchname10
Thanks for any input!
Fails in Chrome but success in Explorer....   :-)
