Prime Infrastructure lists port
ZdenekF
please can you help me? I have a bigger network infastructure and using Prime Infrastructure 3.2. It would help me, when Prime can lists which port has "authentication port-control auto" in configuration in summary for all switches.
Is this possible?
Thank you.
Zdenek
Mark Malone
if your asking can you check all your devices and list whihc runs that command yes you can through compliance section in configuration , create the policy assign it to a profile and then run the job and it ca be exported in excel/csv or html
https://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/3-0/user/guide/pi_ug/compliance.html
