Prime Infrastructure, Port Groups
lars johansson
Hi!
Prime group switch ports as access, link and trunk ports automatically.
Is there some way to force a "rescan and regroup", I have noticed that for some reason the grouping fails and some ports are ungrouped.
I have seen it in different version 3.1 installations.
thanks
/lars
vishal.c07
You can create manul port group, It'll more usefull.
Vishal Chauhan
Yes I know but If I would like to monitor all trunk ports it's a lot of work to scan all devices and create manualy portgroups.
thanks
/lars
