Prime Infrastructure1.3
Qi Chen
Hello everyone
I can use SSH to login PI.username admin, password Admin1234567 role admin.But this accounting cannot login through the browser.
2 Accepted Solutions
Vinod Arya
SSH and GUI username/password may differ.
To login on GUI, the server URL would be https://server_hostname or https://ip.ad.dr.ess. In Cisco Prime Infrastructure 1.3, login using the following credential for the very first time:
Username: root
Password: <the root password is the one that was entered during the install script>
Please note that the root password that is prompted in the install script is only for web access and not access to the CLI.
The admin user is provided with a Cisco IOS® Software-like shell, which is the preferred shell for carrying out most operational tasks.
-Thanks
Vinod
**Rating Encourages contributors, and its really free. **
-Thanks Vinod **Rating Encourages contributors, and its really free. **
You can use following process to reset password. To change the root password, use the ncs password root password command.
ncs passwod root password password
Example:
NDCNETPRIME1-n/admin# ncs password root password T3st123
CompilerOracle: exclude org/snmp4j/Snmp.send
Loading USER - root
Validating new password..
Resetting password ..
Resetting password  COMPLETED.
EXECUTION STATUS : Success
-Thanks
Vinod
**Encourage Contributors. RATE them. **
Vinod Arya
Username: root
-Thanks
Vinod
thank you very much indeed. Now I can login the Prime Infrastructure
If I forget the root password what should I do ? How to change the root password?
-Thanks
Example:
Loading USER - root
-Thanks
Vinod
Very good explanation.
Thank you for your guide.
