Prime LMS 4.2.4 ICServer process shutdown automatically on daily basis
Anas Hijjawi
We are running prime lms 4.2.4, every morning we found that ICServer process is shutdown, once we start it it starts fine, next day again the same.
You know this process is required for the Inventory Collection.
Application is installed on windows, thanks in advance
Thanks, Anas *--* Please rate the useful post,its free ;) *--*
AFROJ AHMAD
Hi Anas,
In the meantime , you can follow the below steps:
1. Stop the ciscoworks and wait for 5 minutes.
2. Increase the ICServer memory heap size from 256 to 512 in
registry for ICServer process
* HKEY_LOCAL_MACHINE->SOFTWARE->Cisco->Resource Manager->Current Version
->Daemons->ICServer       The HEAP (ICServer parm -Xmx512m)
3.start the daemon manager
Keep the eye on the ICserver process and see if it is still failing...
I have attached the screen shot for your referenec ..
Thanks-
Afroz
[Do rate the useful post]
****Ratings Encourages Contributors ****
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
6 Replies 6
AFROJ AHMAD
Hi Anas,
Kindly share the ICServer.log and IC_Server.log (NMSROOT\CSCOPX\LOG)
Thanks-
Afroz
Hi friend:
I am reciving in my e-mail event "inventory change" asociated a this service ICService, but is too much, is possible to disable this traps in snmp ? and where is this option?
Marco.
I had attached picture.
AFROJ AHMAD
Hi Anas,
Thanks-
Afroz
Anas Hijjawi
Hi Afroj and thanks for your reply, is this for prime lms 4.2?
Yes , you can apply this workaround.
But it would be good , if you send me the logs file first then I will check and confirm it accordingly
Thanks-
Afroz
Anas Hijjawi
I will
