Privilege exec command for remote scp?
jph
Visitor
What I wish to do is automatically back up the configuration of all of my devices via SSH. I want to create a user specifically for this purpose, whose only capability is to remotely scp the startup-config from each device.
I am unable to determine what 'privilege exec level <privilege>' command I need to do to enable this. Everything I can think of results in 'Privilege denied' on the remote hosts. Debugging of SSH indicates that the remote session conducts the actual login process successfully.
Thanks.
2 Accepted Solutions
Try this, you don't have to configure any username on the Router for backup purpose.
The router automatically uploads the runing config to a SCP server .
You just need to provide the SCP username/password and path to the SCp server
And then mention the time interval in Minutes.
myRouter1(config)#archive
myRouter1(config-archive)#path scp://scpuser:[email protected]/myRouter-config
myRouter1(config-archive)#time period 1440
You can use $t and $h in the archive file name to substitute the current time and hostname respectively.
6 Replies 6
Joe Clarke
Just make sure your username gets privilege level 15 when it logs in:
username backup privilege 15 password 0 B@ckup123
scp [email protected]:nvram:/startup-config /path/to/backup
Thanks. I think this will pretty much do what I need, though it would be nice to have the config files be timestamped. Maybe it'll be enough to have the recipient server move them automatically.
Thanks.
Sorry, if it wasn't explicit in my message, I did not want to have the backup user have full privileges, in case the password was compromised.
There is no way to do this with local authorization. However, this can be accomplished using an external ACS server.
