problem database.pl in ciscoworks : any help !!!
mohamed louhab
Hey,
i am having problems alot of issues with Ciscowork. I am getting the following messages with the self test.
database.pl
FAIL    Self Test Fail to query rme.DbVersion, Error: Database server not running (DBD: login failed)
        Self Test Fail to query rme.SYSTABLE, Error: Database server not running (DBD: login failed)
Ciscoworks : 2.2
OS : windwos 2000 server
in Attachments: the output of
pdshow.txt
jrm.log
the message error
list of contents under NMSROOT/databases/rme
list of contents under NMSROOT/databases/cmf
Thanks all
Joe Clarke
LMS 2.2 is obsolete, and no longer supported.  You must upgrade.  I recommend you look at LMS 4.0, which is the current latest version and will have the longest life.  That said, it looks like the RME database either has a corrupt transaction log or is corrupt itself.  This database troubleshooting document may help, though the commands will be slightly different (I believe we were using dbeng7 with LMS 2.2).
https://supportforums.cisco.com/docs/DOC-8796
Joe Clarke
