Problem in OID
arun kumar
I ve a problem in our Poller which is getting an OID from a Cisco NPEG1. Following is the error thrown from Cisco box to the poller:
.1.3.6.1.4.1.9.9.166.1.15.1.1.11.3521
Error in packet
Reason: (noSuchName) There is no such variable name in this MIB.
This name doesn't exist: enterprises.9.9.166.1.15.1.1.11.3521
Is it related to any specific problem. When i search the OID .9.9.166.1.15.1.1.11 in Cisco it shows CiscoQosPolicyRate but with .9.9.166.1.15.1.1.11.3521 its not able to detect it.
NPEG1 runs with IOS:12.3(8)T8.
Is there any bugs related to it or any hint observed from the above.
Thanks in advance
Joe Clarke
This is an invalid object for an snmpget. You are missing an index. The cbQosCMStatsTable is indexed by cbQosPolicyIndex and cbQosObjectsIndex. You should walk .1.3.6.1.4.1.9.9.166.1.15.1 to get all the available instances in this table.
