Problem Integration CWorks & ACS
laloville
Yesterday I tried to integrate Cworks (LMS3.1) with ACS but now I lost the Administrator level, I get the access but I don't be able to make changes.
I've the same admin-user and admin-passwd locally and in ACS.
What can I do?
It's possible authenticate locally when CWs is in ACS type?
Lucien Avramov
Level 10
Level 10
You can revert back to local login on the LMS server:
on the CLI
net stop crmdmgtd (assuming you are on windows)
Then run from the cscopx/bin/ directory:
perl ResetLoginModule.pl
Restart the daemons:
net start crmdmgtd
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_common_services_software/3.0.3/user/guide/admin.html#wp379258
Yes, is windows and it works.
Thanks a lot!!!
