Problem with 7304
ktadminadmin
Community Member
In my router 7304 the command 'show diag' represents next results (part of output):
TLB entries : 58
Virt Address range Phy Address range Attributes
0x12000000:0x13FFFFFF 0x012000000:0x013FFFFFF CacheMode=2, RW, Valid
0x14000000:0x15FFFFFF 0x014000000:0x015FFFFFF CacheMode=2, RW, Valid
0x16000000:0x17FFFFFF 0x016000000:0x017FFFFFF CacheMode=2, RW, Invalid
0x18000000:0x19FFFFFF 0x018000000:0x019FFFFFF CacheMode=2, RW, Invalid
0xC6000000:0xC7FFFFFF 0x046000000:0x047FFFFFF CacheMode=2, RW, Valid
0xC2000000:0xC3FFFFFF 0x042000000:0x043FFFFFF CacheMode=2, RW, Valid
0xDC010000:0xDC011FFF
The work of this device is not very stable. What this messages (CacheMode=2, RW, Invalid) means? Is it hardware or software problem?
David Stanford
These are TLB entries and TLB stands for "Translation Lookaside Buffer".
It's a table of relation of Virtual
Address range and Physical Address range that RISC processor uses.
"Invalid" in TLB entries does NOT indicate HW/SW failure. That indicate an address
region that CPU doesn't use.
In this case, "Invalid" address region are defined as follows.
TLB entries : 58
This is no problem.
