Problem with establishing VPN using VMS
zadiklopez
I want to establish a vpn connection between a PIX firewall and a router in my network using the VMS. The thing is that the management centers of both devices (PIX and routers) are not integrated therefore if I want to create a vpn in the Router VPN MC I cant establish the PIX firewall as my hub.
What can I do.
wong34539
Level 6
Level 6
I think you can get some information from the below deployment guide.
http://www.cisco.com/en/US/products/sw/cscowork/ps2330/products_white_paper09186a00801aa80c.shtml
bjames
Level 5
Level 5
Did you ever figure this out? I tried the same thing and want to pull my hair out. I tried configuring each Router MC and Firewall MC for the tunnel but the router MC has different options if the router is a FW/VPN/Hub or spoke, yet I cannot find where to create the peer?
I am NOT impressed with this total product at all
