11-08-2005 05:48 AM
I have created a few test netconfig jobs using email notification.
But when I go to approve each of the jobs they are all greyed out?(rme>job mgmt>job approval) I cannot click approve or next.
Each job fails since no approval has been granted.
Please advise.
11-14-2005 11:12 AM
What is the version of Cisco Works that you are running? How long have you been facing this problem? or is this a new installation. If you are using a older version of the cisco works ensure that you have all the latest patches. If you dont have the patches download it from the Cisco.com site and then try.
11-14-2005 01:17 PM
I cracked it last week.
Thanks anyway.
When I clicked on the email notification link I was then logging in as a non member of the approvers group hence I didnt have sufficient priviledges to approve/reject netconfig jobs.
