Problems with LMS 2.6 backup (error 1226)
rodrigopitta
Hi.
I am tryinng to take a backup from LMS 2.6 in a Windows 2003 system. The backup appears to finish, and some files are generated in the backup directory, including one named filebackup.tar, wich seems to be the RME database backup, but the log file states an error: ERROR(1226): Database rmengdb backup failed. I can't find out what is causing this. I am taking this backup for migration purposes.
Thanks in advance.
This is not good.  Your RME database has become corrupted.  If you have a known good backup of LMS, you should restore it.  If not, you will need to follow the instructions in that same document to reinitialize your RME database.
8 Replies 8
Joe Clarke
This is a line number in the code, and not an error code.  Post the dbbackup.log from the server.
Thank you for your reply.
Here goes the log for the latest backup attempt.
Backup to 'W:/backup_new2' started at: [Fri Jun 18 15:14:30 2010]
Archiving the contents of the following directories into W:/backup_new2\0\campus\filebackup.tar
W:/PROGRA~1/CSCOpx/campus/etc/cwsi\DeviceDiscovery.properties
W:/PROGRA~1/CSCOpx/campus/etc/cwsi\ANIServer.properties
W:/PROGRA~1/CSCOpx/campus/etc/cwsi\discoverysnmp.conf
W:/PROGRA~1/CSCOpx/campus/etc/cwsi\datacollectionsnmp.conf
W:/PROGRA~1/CSCOpx/campus/etc/cwsi\Snmpv3EngineParam.txt
W:/PROGRA~1/CSCOpx/campus/etc/cwsi\UTSnmpv3EngineParam.txt
W:/PROGRA~1/CSCOpx/campus/etc/cwsi/users
W:/PROGRA~1/CSCOpx/campus/etc/cwsi/archives
W:/PROGRA~1/CSCOpx/campus/etc/users
W:/PROGRA~1/CSCOpx/campus/etc/cwsi/ReportArchives
W:/PROGRA~1/CSCOpx/htdocs/campus/maps
/cygdrive/w/PROGRA~1/CSCOpx/bin/tar: Removing leading `/' from member names
Archiving the contents of the following directories into W:/backup_new2\0\cmf\filebackup.tar
W:/PROGRA~1/CSCOpx/lib/classpath/com/cisco/nm/cmf/servlet\cwpass
W:/PROGRA~1/CSCOpx/lib/classpath\sso.properties
W:/PROGRA~1/CSCOpx/lib/classpath/com/cisco/nm/dcr\dcr.ini
W:/PROGRA~1/CSCOpx/MDC/Apache/conf/ssl
W:/PROGRA~1/CSCOpx/www/classpath/com/cisco/nm/cmf/security\secret.dat
W:/PROGRA~1/CSCOpx/www/classpath/com/cisco/nm/cmf/security/jaas\JaasConfig.xml
W:/PROGRA~1/CSCOpx/www/classpath/com/cisco/nm/cmf/security/jaas\JaasConfigModule
W:/PROGRA~1/CSCOpx/www/classpath/com/cisco/nm/xms/psu/maps
W:/PROGRA~1/CSCOpx/objects/data/cmf/cmic/registered-templates
W:/PROGRA~1/CSCOpx/objects/data/cmf/cmic\cmic.xsd
W:/PROGRA~1/CSCOpx/conf\logstat.conf
W:/PROGRA~1/CSCOpx/etc/licenses
W:/PROGRA~1/CSCOpx/MDC/etc\regdaemon.xml
W:/PROGRA~1/CSCOpx/lib/classpath\comUser.dat
W:/PROGRA~1/CSCOpx/lib/classpath\ccoUser.dat
W:/PROGRA~1/CSCOpx/lib/classpath\proxy.properties
Archiving the contents of the following directories into W:/backup_new2\0\dfm\filebackup.tar
W:/PROGRA~1/CSCOpx/objects/smarts/conf
W:/PROGRA~1/CSCOpx/objects/smarts/local/conf
W:/PROGRA~1/CSCOpx/objects/smarts/local/repos
W:/PROGRA~1/CSCOpx/objects/smarts/local/logs
W:/PROGRA~1/CSCOpx/setup\dfm.info
Archiving the contents of the following directories into W:/backup_new2\0\rmeng\filebackup.tar
W:/PROGRA~1/CSCOpx/files/rme/jobs/swim
W:/PROGRA~1/CSCOpx/MDC/tomcat/webapps/rme/WEB-INF/conf/swim/kb
W:/PROGRA~1/CSCOpx/files/rme/swim/advdistinput
W:/PROGRA~1/CSCOpx/files/rme/jobs/syslog
W:/PROGRA~1/CSCOpx/files/scripts/syslog
W:/PROGRA~1/CSCOpx/files/rme/syslog
W:/PROGRA~1/CSCOpx/files/rme/jobs/cda
W:/PROGRA~1/CSCOpx/files/rme/jobs/cctool/jobs
W:/PROGRA~1/CSCOpx/MDC/tomcat/webapps/rme/WEB-INF/classes/com/cisco/nm/rmeng/cctool/scase\SmartCase.properties
W:/PROGRA~1/CSCOpx/files/rme/jobs/bugtool/jobs
W:/PROGRA~1/CSCOpx/MDC/tomcat/webapps/rme/WEB-INF/classes/com/cisco/nm/rmeng/bugtool\Bugtool.properties
W:/PROGRA~1/CSCOpx/MDC/tomcat/webapps/rme/WEB-INF/classes/com/cisco/nm/rmeng/csc/data\Collector.properties
W:/PROGRA~1/CSCOpx/files/rme/cfgedit
W:/PROGRA~1/CSCOpx/MDC/tomcat/webapps/rme/WEB-INF/classes/com/cisco/nm/rmeng/config/cfgedit\ConfigEditor.properties
W:/PROGRA~1/CSCOpx/setup\rme.info
W:/PROGRA~1/CSCOpx/files/rme/repository
W:/PROGRA~1/CSCOpx/MDC/tomcat/webapps/rme/WEB-INF/classes/com/cisco/nm/rmeng/repository/common\repository.properties
W:/PROGRA~1/CSCOpx/files/rme/jobs/NetShow
W:/PROGRA~1/CSCOpx/files/rme/NetShow/ShowCommandArchive
W:/PROGRA~1/CSCOpx/files/rme/jobs/inventory/reports/archives
W:/PROGRA~1/CSCOpx/files/rme/jobs/inventory/reports/jobs
W:/PROGRA~1/CSCOpx/MDC/tomcat/webapps/rme/WEB-INF/classes/com/cisco/nm/rmeng/fcss/data\TimeZone.lst
W:/PROGRA~1/CSCOpx/MDC/tomcat/webapps/rme/WEB-INF/classes/com/cisco/nm/rmeng/util/logger\rmelog.cfg
W:/PROGRA~1/CSCOpx/files/rme/dcma
W:/PROGRA~1/CSCOpx/files/rme/jobs/ArchiveMgmt
W:/PROGRA~1/CSCOpx/files/rme/jobs/ArchivePoller
W:/PROGRA~1/CSCOpx/files/rme/jobs/ArchivePurge
W:/PROGRA~1/CSCOpx/files/rme/jobs/ArchiveUpdate
W:/PROGRA~1/CSCOpx/files/rme/jobs/cas
W:/PROGRA~1/CSCOpx/files/rme/changeaudit
W:/PROGRA~1/CSCOpx/files/scripts/changeaudit
W:/PROGRA~1/CSCOpx/files/rme/jobs/NetConfigJob
W:/PROGRA~1/CSCOpx/files/rme/jobs/cri/purgejobs
W:/PROGRA~1/CSCOpx/files/rme/cri/archives
Backing up database aniDb:Adaptive Server Anywhere Command File Hiding Utility Version 9.0.0.1383
Adaptive Server Anywhere Backup Utility Version 9.0.0.1383
(68183 of 68183 pages, 100% complete)
(2 of 2 pages, 100% complete)
Database backup completed
Command file created using Adaptive Server Anywhere Command File Hiding Utility.
Adaptive Server Anywhere Validation Utility Version 9.0.0.1383
No errors reported
Backing up database rmengdb:Adaptive Server Anywhere Command File Hiding Utility Version 9.0.0.1383
Database backup failed
Database backup not started
Backup rmeng to W:/backup_new2\0\rmeng\database\rmeng.db failed. Retry backup database rmeng
Backup rmeng to W:/backup_new2\0\rmeng\database\rmeng.db failed second time.
ERROR(1226): Database rmengdb backup failed and . Check the log file for information.
Backup failed: 2010/06/18 20:25:28
See this document: https://supportforums.cisco.com/docs/DOC-8796 .  Run the database validation command against the rmeng DSN.  What output do you get?
The validation command includes configureDB.pl, wich does not exist in my client's server. I think it is because the doccument reffers to LMS 3.1 and 3.2, but I'm working on a LMS 2.6. Is there any other way to run the validation or to retrieve the configureDB.pl?
The script is called configureDb.pl, and it does exist in LMS 2.6.  It can be found in NMSROOT/objects/db/conf/configureDb.pl.  It will work the same way as under LMS 3.1 and 3.2.
Thank you.
The output was:
2 errors reported
Dbspace for table 'SYSLOG_20090415' not found
Dbspace for table 'SYSLOG_20090418' not found
ERROR: [StandardDbUpgrade] Validation of rmeng database failed
Ok, no way out, I'll have to reinitialize.
Thank you for your help.
