Problems with Resource Manager Essentials 4.3
Daniel Mansilla
Frequent Visitor
Frequent Visitor
Hi my name is Daniel.
I am  having problems with Cisco Works Resource Manager Essentials 4.3.
My problem is the next: some time ago I was having problems when I  was making my report with the RME aplication. So to solve the problem, I  reinstalled the application RME
Unfortunately after reinstalling aplication  the previous data no  appear . The first thing I would like to know is whether it is possible  to recover data you had before you reinstall the application and my  second problem is that I currently no records the configuration for the  communications equipment .
Best Regards
7 Replies 7
David Stanford
2 questions:
1) Did you do a backup before you did a reinstall of the application? If you reinstalled without a backup it isn't going to be saved.
2) Which reports are you referring to?
Thanks you for you help.
1.- Yes but I dont know how load my backup.
2.- I refer a when I do one change in my equipments of comunication. The RME should save my changes and show in the Audit Changes but is not doing.
Regards...
Daniel Mansilla
If its a good backup then have a look for restorebackup.pl in LMS. The online help will have details on how to run the script with parameters.
For the other issue there are a few things you should check:
1) Are the devices managed in RME?
2) Do you have syslog enabled on the device to LMS?
3) Are the devices having configs archived successfully?
Ok, I search the information for load backup.
Yes, I have 75 devices managed with RME
Yes, I is enabled
I dont now, you can tell me how do this?
Greatings
Daniel M
Check under RME - Config Mgmt - Archive Mgmt - Search Archive
check the device and see if it has archived any running / startup configs
You can tell me how I could restore my LMS with my backup. I not found any easy tutorial with this information.
Please tell me the procedure.
Thanks for you help.
Sorry but I need to you help for found the tutorial for reload backup created before uninstall RME.
Am waiting you response.
Greatings
Daniel M
