Problems with RME Syslog (LMS 3.1 with W2003)
g.palavecino
Hello, I'm Guilliano and have problems with the operation of syslogcollector and sysloganalysis. The current situation is:
* Unsubscribe the host that was active and I can not subscribe to another host because I get the error: SLCA0152 and SLCA0126. I followed the steps in the User Guide 4.2, and Instalation Guide RME LMS 3.1 and I can not solve the problem. I try to create the certificate that indicates the error in the Commun Services, but does not believe it.
* In windows critical messages appears: DCR is down or inaccessible.
In advance, thank you very much.
Sincerely,
Guilliano Palavecino R.
Support Engineer
Adexus S.A
16 Replies 16
Okay, now there is a problem reading the syslog.log file. Make sure NMSROOT\log\syslog.log is accessible by the casusers group. This group should have full control over the file.
JClarke thank you very much, the problem has been solved completely. Syslog.log file did not allow access to the group casus.
Again thanks and greetings from Chile.
Enginner Support Communication
Adexus S.A
Santiago, Chile.
