python to configure switches
Kobus Raath
Visitor
I am having some issues writing a basic python script to configure access switches in mass.
The process I am trying to follow is –
Connect the switches to the lab network, issue IP address from a DHCP server and use auto config to load a base config (set the username, enable local login).
The python script will do the following-
  • Read the IP list file
  • Log in to the devices one by one
  • Update firmware (must still be completed)
  • Optionally load a config update file
  • Load a custom config file (based on device sn)
  • Gen new rsa key
  • Save config
  • Backs up new running config.
If I write this, one command following on the other it seems to work.
However. In order to provide more flexibility, I would prefer to write separate definitions and call these as I need them.  This works to a limited extent.
The process to call the individual definitions works.  The expect statements do not seem to function beyond the first definition that I call.  My suspicion is that the expect telnet instance gets interrupted and do not continue to function as too as the first definition is completed.
Hoe do I get the pexpect child statement to work on the subsequent definitions?
from __future__ import print_function
import argparse
import commands
import ConfigParser
import glob
import os
import paramiko
import pexpect
import re
import select
import shutil
import signal
import string
import sys
import syslog
import time
import traceback
from binascii import *
from cmd import *
from ftplib import *
from netmiko import *
from optparse import *
from paramiko import *
from paramiko.ssh_exception import *
from paramiko.py3compat import *
# from pyRouterLib import *
from StringIO import StringIO
# system parameters
switch_username = 'admin' # edit to reflect
switch_telnet_password = 'C1sc0312' # edit to reflect
switch_enable_password = 'C1sc0312'  # edit to reflect
ftp_username = 'user'  # edit to reflect
ftp_password = 'password'  # edit to reflect
configuration_server = "172.30.12.150"  # edit to reflect
host_list = open('/root/PycharmProjects/scripting/ip_address_list.txt', 'r')
firmware_2960 =
'c2960-ipbase-mz.122-35.SE5.bin'
firmware_3560 = 'c3560-ipbase-mz.122-35.SE5.bin'
min_flash_req = 10000000
rsa_key_length = 2048
def login_to_node ():
# use Telnet
try:
        child = pexpect.spawn(
'telnet %s' % (host))
        child.expect(
'Username:')
        child.sendline(switch_username)
        child.expect(
'Password:')
        child.sendline(switch_telnet_password)
        child.expect(
print(("Successfully Telnetted to host "), (host))
except:
try:
#child.expect('>')
child.sendline('enable')
            child.expect(
'Password:')
            child.sendline(switch_enable_password)
            child.expect(
print(("Successfully Telneted to host "), (host), (',and enabled console'))
except:
print(("Failed to Telnet to host "), (host))
return
# update firmware
def update_firmware ():
try:
# check platform
        # child = pexpect.spawn()
        # check model
child.sendline('show version | include Model number')
#child.expect('(?:Processor\sboard\sID\s)(\d|\w{11})')
        #hardware_model = child.after[-11:]
        # check running firmware
child.sendline('show version | include MSystem image')
        #firmware = child.after[-11:]
        # check available space
child.sendline('show flash | include bytes total')
        #flash_available = child.after[-11:]
        # upload new firmware
        # confirm md5
        # set boot variable
        # delete old firmware
        # notify upgrade
        # reboot
print (("Successfully updated firmware on host "), (host))
except:
print(("Failed to update firmware on host "), (host))
return
# load configuration update
def load_config_update ():
try:
# copy config file to unit
child.sendline('copy ftp: flash:')
        child.expect(
'[Address or name of remote host []?]')
        child.sendline(configuration_server)
        child.expect(
'[Source filename []?]')
        child.sendline(
'temp_config.cfg')
print("Using device config file temp_config.cfg")
        child.sendline(
'temp_config.cfg')
        child.expect(
        child.sendline(
'temp_config.cfg')
        child.expect(
print(("Successfully copied files to flash "), (host))
# copy config to running config (append current)
try:
            child.sendline(
'copy flash:temp_config.cfg running-config')
            child.expect(
            child.sendline(
'running-config')
            child.expect(
print(("Successfully copied files to running-config "), (host))
except:
print(("Failed to copy files to running-config "), (host))
except:
print(("Failed to copy files to flash "), (host))
return
# load custom config
def load_custom_config():
try:
# get unit info
child.sendline('show version | include Processor')
        child.expect(
        device_id = child.after[-
11:]
        serial_number = device_id
print(("This is Device-ID "), (device_id))
print(("This is Device-SN "), (serial_number))
        config_file =
'%s.cfg' % serial_number
        child.expect(
        child.expect(
print(("Using device config file "), (config_file))
        child.sendline(config_file)
        child.expect(
        child.sendline(
'temp_config.cfg')
        child.expect(
# copy config to running config (replace current)
try:
            child.sendline(
            child.expect(
            child.sendline(
'running-config')
            child.expect(
except:
except:
return
# generate new crypto key
def generate_rsa_key ():
# check current key
   # generate new key
try:
child.sendline('crypto key generate rsa')
       child.expect(
'(512)')
       child.sendline(rsa_key_length)
       child.expect(
print(("Successfully generated new RSA key on host "), (host))
except:
print(("RSA key gen failed on host "), (host))
return
# save running config
def save_running_config():
try:
#child = pexpect.spawn()
child.expect('#')
        child.sendline(
'write memory')
        child.expect(
'[OK]')
        child.expect(
print(("Successfully saved the running-config on "), (host))
except:
print(("Failed to save the running-config on "), (host))
#return
# backup running config
def backup_deployed_congig ():
#child.sendline('quit')
return
# test function
def test_function ():
try:
print(("Successfully ran the test function on host "), (host))
except:
print(("Test function failed on host "), (host))
return
for line in host_list:
    host = line.split()[
0]
print(("Start configuration on host "), (host))
    platform =
None
hardware_model = None
firmware = None
flash_available = None
device_id = None
serial_number = None
config_file = None
login_to_node ()
#update_firmware ()
    #load_config_update ()
    #load_custom_config ()
    #generate_rsa_key ()
save_running_config ()
#backup_deployed_congig ()
test_function ()
0 Replies 0
