QoS Monitoring on Cat 3550
zengxing
I would like to use NMS to poll the MIBs via SNMP to collect the statistics of the QoS performance on the switch Cat 3550. Some of the items I am interested to monitor are:
1. Packets dropped due to non-conformance;
2. Bandwidth of each class of traffic (e.g. VoIP ? EF, DSCP 46) at the juncture of being polled;
3. Tail drop / WRED occurred for which particular queue in the cat3550 egress interface.
Is this information available on Cat 3550
when QoS feature is enabled? Any software recommended to do the monitoring?
David Stanford
Have a look at the CISCO-PORT-QOS-MIB
There are numerous objects in this MIB to monitor aspects of QoS
ftp://ftp-sj.cisco.com/pub/mibs/supportlists/cat3550/cat3550-supportlist.html
Case Solution:
when you say "limit bandwidth utilization" you will need a policer or shaper. The command "bandwidth 64" does not do it.
You would need
policy-map test
class MaxRate
police 64000
as a minimum configuration. Have a look at
"Understanding QoS Policing and Marking on the Catalyst 3550"
http://www.cisco.com/en/US/products/hw/switches/ps646/products_tech_note09186a00800feff5.shtml
