Read Write access priviledge
csn000004
Frequent Visitor
Frequent Visitor
Dear All,
My query is that can Cisco devices (Router,Switch,ASA) can be authenticated by two persons password at a same time in order to change any configuration (means when read write access is required). Requirement is that not a single user can change the configuration of the devices, there must be 2 users authentication required to edit the configuration. ACS is already running in my environement, users are authenticated by ACS.
I just want to know that if there is any solution available in the market. Please respond.
AFROJ AHMAD
Hi ,
I think , yes you can do it . you need to have  2 SNMPv3 users configured on the device and both the user should be the part of the Guroup which have the RW access.
Thanks-
Afroz
**Rating Encourages Contributors ****
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Dear Afroj
Can you please describe this solution in detailed? didnt get your point.
Hi ,
create 2 user like below on the switch ::
Switch(config)#snmp-server view myview iso included
Create SNMP v3 Group:
Switch(config)#snmp-server group cisconms v3 auth read myview write myview
Switch(config)#snmp-server user
Switch(config)#snmp-server user cisco ?
  WORD  Group to which the user belongs
Create SNMP user:
Switch(config)#snmp-server user cisco cisconms v3 auth md5 cisco123 priv 3des 123cisco
Switch# sh run | i snmp
Switch#show snmp user
User name: cisco
Engine ID: 8000000903000021568D2A81
storage-type: nonvolatile        active
Authentication Protocol: MD5
Privacy Protocol: 3DES
Group-name: cisconms
then check if it works, i haven't tested but it looks straight forward
Thanks-
Afroz
