We are building network systems with up to 1000 hosts and up to 100 switches. Up to now we have been using switches from another provider and want to switch to Cisco if necessary.
The MAC address and the configured IP address of the hosts are known. We use a tool to read out the switches with an SNMP walk in order to be able to document the port assignment. We need this to be able to restart the host via the switch in the event of a fault (power off-power on). For test purposes, we have the following Cisco switches in use in a test setup for the time being:
- SF350-48P
- SG350-28MP
- SG350-10P
Question:
Which SNMP walk can be used to query Cisco switches that return the MAC address and the associated port as a response?
or
How is it possible to obtain this information?
Many thanks in advance
Greetings
Itchley
