Recommend firewall software for ASA 5510
itech
Looking for a firewall software which can generate traffic report, web usage report, mail usage report and protocol report etc.
The best is the software is free of charge. Thanks
itech
Anyone care to share? Thanks
Lucien Avramov
Level 10
Level 10
You can use : Cisco Performance Monitor, part of CSM for this:
http://www.cisco.com/en/US/products/ps6498/tsd_products_support_series_home.html
You can use MRTG to pull the snmp data for free, but that will just be for BW monitoring
