Recommended topology for a company
robad
Hi All,
We are going to take responsibility on a new company's network, and we thought about 3 options how to do it.
Right now, their network is going out to their global IT, with 2 old 3750 catalyst connected to IT switches.
"Below" of those 3750, there is all their internal networking, including switches/storage/servers/clients.
3 options are :
1. Pair of Nexus 9000 with Switch-Profile (conf sync) :
Advantages are Nexus ! the BW, the amount of 40 GB ports (for future use) + we can use FEXes, and manage whole networking from one pane of glass.
But, I'm afraid of the 'switch-profile'. I heard that it have some bugs.... what do you say ?
2. One Nexus 9000 (and another one will be installed in the rack, powered-off. and if the main one will be faulted, we'll power-on , and move the config + connections to it)
Advantages are the same as before. and in this option, I don't need to 'switch-profile' headache
3. Pair of catalyst 9300
It's the most simple way. but the disadvantages is that I won't have one pane of glass
I'll be glad to hear your opinion on the advantages/disadvantages of those options.
Thanks in advance
pieterh
this is not completely true,
if you "stack" these switches (either physical or virtual), you still have one pane of glass (one management IP)
( virtual not possible according to Solved: Stackwise Virtual connection between two Switches Catalyst 9300 - Cisco Community )
