Regarding default credential sets
gautamzone
Level 6
Level 6
Dear friends,
I have created 3 credentials sets and 6 credential set policies.
How do i know if a device has got bound successfully to the default credential set that i created?
Thanks and Regards
Gautam
Joe Clarke
You can export the DCR entry for the device, and check.
Joe Clarke
Thats fine Jason.
I tried doing a RME sync archive to test it but it failed.
I just edited the device credentials directly and used them for RME sync archive and it worked.
Thanks a lot
Gautam
