Regular Expressions in IOS
I am having a tough time with this one.
I need to show all the entries for a network, say 10.1.20.0/24.
If I do "sh run | in 10.1.20." I get what I need, plus stuff I don't need... Such as entries for networks like 10.1.201, 10.1.203, etc.
I've never been particularly good with regex, and I figured that the following would work:
sh run | in 10.1.20.$
But it did not.
I can't find a really good example on Google, so I figured I'd turn to the pros!
Thanks all!
Chris McGarrah
Try this:
sh run | in 10\.1\.20\.
The dot matches any character in regex.  Putting the \ in front of it tells it you want to look for the dot.
Chris McGarrah
Try this:
Richard,
Chris has already shown you how to solve it; I just wanted to add this link:
http://www.cisco.com/c/en/us/td/docs/ios/12_2/termserv/configuration/guide/ftersv_c/tcfaapre.html
Rolf
