Remove IP From Object Group using Restconf
JamesMathis
Frequent Visitor
Frequent Visitor
I was hoping we could get some assistance with a Restconf API call.  We are trying to remove an IP address from our blocklist sources object group on an ASR-1001x.  We have no problem adding IP's and subnets to the object group.  I was thinking that we could change the PATCH method to a DELETE method to accomplish the task.
However, when we did this we receive the following error message:
{ "errors": { "error": [ { "error-message": "Operation not allowed.", "error-tag": "malformed-message", "error-type: "application" } ] } }
The following curl is what we sent to the router:
curl --request DELETE --insecure -H 'Content-Type: application/yang-data+json' -u 'user:password' \
https://X.X.X.X/restconf/data/Cisco-IOS-XE-native:native/object-group/Cisco-IOS-XE-object-group:network=blacklist_sources/obj-Mode-config-network-group/host \
--data '{"Cisco-IOS-XE-object-group:host":[{"ipv4-host":"1.2.3.4"}]}'
Does anyone know how to properly format this so that we can remove the IP?  We will also need to remove subnet's at some point as well, but I feel like once we get IP's working we can modify it for subnets.
Any assistance is appreciated.
Dan Frey
Here is an example for hosts and networks.
HOSTS:
dafrey@raggedtooth:~$ curl --request GET --insecure -H 'Content-Type: application/yang-data+json' -u 'user:xxxxxxxxxx' https://192.168.0.20/restconf/data/Cisco-IOS-XE-native:native/object-group/Cisco-IOS-XE-object-group:network=blacklist_sources/obj-Mode-config-network-group/host
  "Cisco-IOS-XE-object-group:host": [
      "ipv4-host": "1.2.3.4"
      "ipv4-host": "4.3.2.1"
      "ipv4-host": "5.6.7.8"
dafrey@raggedtooth:~$ curl --request DELETE --insecure -H 'Content-Type: application/yang-data+json' -u 'user:xxxxxxxxxx' https://192.168.0.20/restconf/data/Cisco-IOS-XE-native:native/object-group/Cisco-IOS-XE-object-group:network=blacklist_sources/obj-Mode-config-network-group/host=5.6.7.8
SUBNETS:
dafrey@raggedtooth:~$ curl --request DELETE --insecure -H 'Content-Type: application/yang-data+json' -u 'user:xxxxxxxxxx' https://192.168.0.20/restconf/data/Cisco-IOS-XE-native:native/object-group/Cisco-IOS-XE-object-group:network=blacklist_sources/obj-Mode-config-network-group/network_address=10.2.1.0,255.255.255.0
dafrey@raggedtooth:~$ curl --request GET --insecure -H 'Content-Type: application/yang-data+json' -u 'user:xxxxxxxxxx' https://192.168.0.20/restconf/data/Cisco-IOS-XE-native:native/object-group/Cisco-IOS-XE-object-group:network=blacklist_sources/obj-Mode-config-network-group/network_address
  "Cisco-IOS-XE-object-group:network_address": [
      "ipv4_addr": "10.1.1.0",
      "ipv4_mask": "255.255.255.0"
Dan Frey
HOSTS:
SUBNETS:
Thanks Dan.  This was very helpful and we were able to complete our use case.
