Removing Communities from CNA
thomascollins
Level 3
Level 3
Using CNA 4.0. I have a lot of communities I've created, and they all show up at the "Connect To" dialog box that opens when you start CNA.
Is there a way to remove devices/communities from that list? I have some that are no longer needed.
I know I can edit my communities (and even delete them) from Application | Communities. But they still show up on the "Connect To" drop down list at startup.
Tom
troystandefer
I had the same problem. I searched my C drive for the files and folders named community and deleted all of the files and folders in it. I don't remember exactly where it was. After deleting the files the communities were gone in CNA. Hope this helps.
