Return traffic not allowed in the DMZ - ASA firewall
BernardoZakur
Hello
I'm trying to build a topology with a firewall, and after configuring the firewall, it won't allow return traffic to go inside the DMZ. I can send ICMP packets to outside, but the return traffic is blocked when it reaches the firewall. I also can't ping from outside to devices in the DMZ. When I click on the PDU Information icon, it says that the ASA doesn't allow traffic from lower security levels to advance to higher security level areas, but I read that return traffic shouldn't be blocked. Any idea to why this is happening? I used the ASA 5506. Thank you!
Deepak Kumar
There are some golden rules as If you want to transfer traffic from Lower level to higher level then you NAT and ACL. Cisco ASA is not inspecting ICMP in default configuration so you have to inspect ICMP protocol for allow Ping from inside to outside also.
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Hey, Deepak, thank you for your reply.
I have already issued the inspect ICMP command, but it still won't allow me to get return traffic, or to ping from the outside.
ASA Version 9.6(1)
hostname ciscoasa
names
interface GigabitEthernet1/1
nameif inside
security-level 0
ip address 200.1.1.2 255.255.255.0
interface GigabitEthernet1/2
nameif dmz
security-level 50
ip address 172.168.1.1 255.255.255.0
interface GigabitEthernet1/3
no nameif
no security-level
no ip address
shutdown
interface GigabitEthernet1/4
no nameif
no security-level
no ip address
shutdown
interface GigabitEthernet1/5
no nameif
no security-level
no ip address
shutdown
interface GigabitEthernet1/6
no nameif
no security-level
no ip address
shutdown
interface GigabitEthernet1/7
no nameif
no security-level
no ip address
shutdown
interface GigabitEthernet1/8
no nameif
no security-level
no ip address
shutdown
interface Management1/1
management-only
no nameif
no security-level
no ip address
object network dmz
subnet 172.168.1.0 255.255.255.0
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
inspect icmp
service-policy global_policy global
telnet timeout 5
ssh timeout 5
This is the current config on the firewall.
I was actually following some YT tutorials and I believe I did exactly what the tutorials told me to do, and when I get to the inspect ICMP command, although the command is successful, the pinging is not... I'll try to dig a little bit deeper, maybe even try to configure the whole thing again, hopefully it works this time.
@BernardoZakur I agree with your answer. Really you have explained as Professor teaches us in college.
