RME Automatically add devices?
a.goldsmith
I'm running 2 servers in a DCR master/slave scenario and for some reason RME is not automatically adding the devices into the inventory.
I've had to manual add them via RME/Devices/Device Managment/RME Devices/Add Devices/ Add all.
I've checked the 'Automatically Manage Devices from Credential Repository' and this is ok.
Any one got any ideas?
Joe Clarke
Enable Device Management Operations debugging under RME > Admin > System Preferences > Application Loglevel Settings. Then try removing one device from DCR, then add it back. Then check the EssentialsDM_Server.log for errors. Of course, removing an re-adding the device from DCR may just work.
Yep, looks like the inintial adding of DCR devices into RME on the slave was stuck.
Once I added all, seems to remove and add ok on RME (Slave). Weird, but seems ok now.
