RME Device Allocation Summary not synchronise.
baotran09
By default, Cisco RME doesnt discover devices in the network, it is automatically populated from the devices in DCR.
I have enabled RME to auto populate from the DCR, however, it still showing differnt value, as shown below:
Device Allocation Sumamry
Application                                       Managed Devices
Device Fault Manager                       90
Campus Manager                             89
RME                                               90
Internetwork Performance Monitor      90
Any ideas?
Sven Hruza
Level 4
Level 4
Do you have 90 devices in DCR, is that right? So you don't have a problem with RME?!?
The one device, that is missing in Campus Manager could be an effect of a cluster configuration of one switch.
If you have a cluster master with one cluster member only the master will be discovered by data collection of Campus Manager.
The informations about the cluster member will be delivered by the master.
