03-18-2009 11:12 AM
LMS 3.1 - Solaris 10.
I've few devices that're in the "Normal Devices" section but are linked to "Unknown Device Type".
The snmpget works and the device is being polled but there's no inventory collection information at all.
Even a direct snmpwalk from the server works.
If I take a look at the device inside "Device Center", no Inventory Collection are present.
I've different kind of models in this list.
All device packages are installed. Cmf, cvw, rme packages are up to date.
Thanks.
03-18-2009 02:57 PM
What are the sysObjectIDs from these devices?
03-18-2009 07:34 PM
I give you few different examples :
SNMPv2-MIB::sysObjectID.0 = OID: SNMPv2-SMI::enterprises.9.5.58
SNMPv2-MIB::sysObjectID.0 = OID: SNMPv2-SMI::enterprises.9.1.485
SNMPv2-MIB::sysObjectID.0 = OID: SNMPv2-SMI::enterprises.9.5.59
I don't think that's objectID related, because it seems to be a lot of different objectID.
Thanks.
03-18-2009 08:17 PM
This could be caused by a bad MDF. How do the devices show up in Common Services > Device and Credentials > Device Management?
03-19-2009 07:15 AM
03-19-2009 10:34 AM
Please post the NMSROOT/lib/classpath/com/cisco/nm/cwcs/mdf/mdfdata.xml file. You are sure that all 188 of these devices are in a Normal state in RME, and not Pre-deployed?
03-19-2009 11:38 AM
03-19-2009 11:48 AM
Remove one of these unknown devices from DCR, then re-add it. Leave the type as unknown, but make sure you enter the correct SNMP credentials. If RME auto-sync is enabled, wait a minute or two, then check the device's status. If RME auto-sync is not enabled, go to RME > Devices > Device Management > RME Devices > Add. Add the device from DCR, and see if its type changes.
03-19-2009 12:04 PM
I've deleted one node from the DCR (common services) for all applications.
After that, I've re-add manually inside "Common Services" ... "Device Management".
Inside RME the device was pending and after few seconds in Normal, still "?".
I've ran a snmpwalk from LMS (command line) to the device. It's take me around 5 minutes to gets through all MIBs. Could it be a timeout somewhere ?
03-19-2009 12:05 PM
Post the EssentialsDM_Server.log and EssentialsDM.log.
03-19-2009 12:22 PM
03-19-2009 10:47 PM
Enable DeviceManagement Operations debugging under RME > Admin > System Preferences > Application Loglevel Settings. Delete one of the unknown devices from DCR, and re-add it. Wait until the device becomes normal in RME, then post the same logs.
03-23-2009 08:35 AM
03-23-2009 10:36 PM
There does appear to be a problem here, but it is not clear exactly where the problem is. A sniffer trace would need to be captured. I recommend you open a TAC service request so additional data can be captured.
03-24-2009 12:20 PM
Thanks.
