RME device inventory on LMS 2.6
eliaspaulos
I have 2 devices their config are archived on RME however RME unable to collect inventory. every inventory job has been failed. and I couldn't found any reason for the failure only I got "inventory never collected" what is the probable cause? thanks.
That's the problem. There is a known loop in the ENTITY-MIB in this version of IOS. You need to upgrade to 12.3(2) or higher.
6 Replies 6
Joe Clarke
You'll need to post the IC_Server.log after running an inventory collection against these devices.
Thanks,I have attached the log.
Are these routers running 12.3(1)?
appears to be...here is sh ver. output
IOS (tm) C2600 Software (C2600-ENTBASE-M), Version 12.3(1a), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2003 by cisco Systems, Inc.
ok,Thanks
