03-21-2008 04:05 PM
If I'm trying to push an image that is too big for free flash, are there any options in RME to delete the existing image to create the needed space?
thanks!
03-22-2008 12:11 PM
RME will detect that there is not enough space, and erase the flash. This will be presented in a warning:
SWIM1049: The selected image requires Flash to be erased during image upgrade. Check whether you have performed the necessary backup.
Log in to Community
