RMON and ATM circuits
epelser_2
I'm trying to setup RMON on an ATM circuit to do the following:
1) To alert the management system when the link utilization reaches 85%
2) To alert the management system when the link utilization drops below the 85% mark
I would prefer to achieve this by specifying a percentage as apposed manually calculating the 85% mark in bits/second as the command can be rolled out to various sites which may have different link speeds.
Does anyone know the following:
1) What mib is required to achieve this?
2) What commands are required to achieve this. (excluding SNMP server commands)
Thanks. EP
David Stanford
If your devices supports basic mini rmon you can do something like shown in this link:
http://www.cisco.com/warp/public/477/RMON/18.html
However, this will use octets and not actual % values.
If you have a NAM it can be much easier using the graphical interface that comes with it.
If you have CiscoView you could also like at the miniRmon tool
