Route summarization with EIGRP
aguila3380
Community Member
Does the ip summary-address eigrp interface configuration command only permit one summarized address per interface to be advertized,or could it take mutiple summarized routes like in a scenerio where you have two summarized routes?
for example:
The network ID's: 192.168.5.64/28, 192.168.5.80/28, 192.168.5.96/28, 192.168.5.112/28, 192.168.5.192/28, and 192.168.5.208/28 are all summarized by the two addresses 192.168.5.64/26 (for addresses 64-127), and 192.168.5.192/27 (for addresses 192-223). Would these two addresses be put in separately like so:
Router(config)#ip summary-address eigrp 192.168.5.64 255.255.255.192
Router(config)#ip summary-address eigrp 192.168.5.192 255.255.255.224
OR:
Router(config)#ip summary-address eigrp 192.168.5.64 255.255.255.0
which would be the summary address for 192.168.5.64/26, and 192.168.5.192/27
If you could, give me a couple of your own examples to go along with my own, to help me better understand.
k.poplitz
Level 7
Level 7
You can have multiple summarized address configured using the ip summary-address eigrp command
