Router not taking commands through TCL
Following is the TCL script i wrote to log show commands wonder why i couldnt see the output. Please let me know if there are any changes to be done.
package require Expect
spawn telnet 10.1.2.12
expect "Username:"
exp_send  "user\r"
expect "Password:"
exp_send "pass\r"
expect ">"
exp_send "en 4\r"
expect "Password:"
exp_send "pass\r"
expect -re "#"
set filename "tcloutput.txt"
sleep {2}
exp_log_file -a $filename
exp_send "show clock "
sleep {2}
exp_send "show ip interface brief "
sleep {2}
exp_log_file
Joe Clarke
On your last line, try:
puts $expect_out(buffer)
Hi Joseph,
Tried the command but no change in the output.
As per my understanding commands are getting executed on router but i am unable to log that output to file. Could any one help me out if i have to make any changes on loggin the output.
I had assumed you just weren't seeing the output from the script.  Now I have no idea what symptoms you're seeing.  Since you haven't provided enough details, the best I can offer is the attached Expect script I have used to grab output from a device.  Perhaps you can adapt it to suit your needs.
