07-04-2023 07:55 AM
In a homenetwork Who should I let the DHCP rol? the router or the switch?
Solved! Go to Solution.
07-04-2023 08:54 AM
Hello @pedrolobaton,
switches typically do not have built-in DHCP capabilities. Switches are primarily responsible for connecting devices within a local network, providing Ethernet connectivity, and forwarding data packets based on MAC addresses. While some advanced switches may have limited DHCP relay functionality, it is still recommended to rely on the router for DHCP services in a home network.
07-04-2023 08:05 AM
I would lean toward the device which is the L3 routing core for your home network.
07-04-2023 08:13 AM
both can config as DHCP local server
only for SW can support DHCP local server if L3 is enable and it have SVI for than VLAN
which one is better ? for me the closest L3 interface to host the more prefer one
07-04-2023 08:54 AM
