Running and startup Config question
stevejhale
LMS 2.6 RME 4.0.6
When I view the diff between running and startup configs I see some diffs that I do not want to record, the example below shows an NTP Clock statement and a crypto How can I stop these showing up as a diff?
xxx-Version-Startup
Global
ntp clock-period 36028899
Crypto-Crypto PKI-Crypto PKI Certificate chain TP-self-signed-2664494464
certificate self-signed 01 nvram:IOS-Self-Sig#3434.cer
XXX-Version-Running
Global
ntp clock-period 36028902
Marvin Rhoads
You can exclude uninteresting differences via the GUI. Select Resource Manager Essentials > Admin > Config Mgmt > Archive Mgmt > Exclude Commands.
Marvin Rhoads
