12-23-2004 04:57 PM
I am not sure if this is possible.
Is there a way, where I can schedule RME or ANI to import from a Remote NMS.
I know you can do this manually, but I prefer to automate this.
I'm running CW2K on Windows.
Jason.
12-29-2004 01:21 PM
As far as I know, you cannot do any such schedules to automatically import.
12-29-2004 02:54 PM
Thanks for the response.
Do you know if you can access the d/b directly to do uploads.
ie maybe using SQL statement to upload the d/b or maybe setup a unix cron job to push the data across.
cheers,
Jason.
